- Jan 7, 2016
- 3,355
I tried FreeCad after they released version 19 I think. Even though the UI was supposed to be much improved I found it to be cumbersome to say the least. Actually, if I am honest, it was just terrible. Then again, I am used to Solidworks.Why? Seems like a blanket rejection, so I'm asking what is the issue? If legit, I'm ok with that. Everything can be improved, including commercial CAD packages, nothing is perfect. All tools have their pluses and minuses.
I use FreeCAD. It works ok. It's free, and not so hard to learn. You can also do FEM with it, I have. Also CFD. Ran CFD on a high speed rocket like projectile. There's a CAM module, but I don't have a way to take advantage of that now. The point is that the tool is capable.
Shock waves on the nose and edges of the fins. Partial vacuum at the tail. Atmospheric pressure is 100KPa. (100,000 Pa)
Less esoteric is a box I modeled and printed for my ELS controller that I designed. Designed the PCB using KiCAD. Both open source tools.
D-shape for connectors in the rear. Left side has pockets for magnets to retain the unit on the head stock of the lathe. PCB is held down by screws. Box (housing) designed in FreeCAD. With lid and everything transparent.
Shoehorning the real thing into the box.
Running on the lathe. Cut an 11 TPI thread, because I could. The ELS bits and brackets were all modeled using FreeCAD. Heck the ER-40 set true back plate was modeled on FreeCAD as well. Machined that from a raw slice of cast iron. Motor mount NEMA24 designed in FreeCAD.
View attachment 494642View attachment 494643
View attachment 494644View attachment 494645
I modeled part of the lathe to understand how to set up things, check out alignment and work out what I needed to machine.
To bring it back to 3D printers, here's a quicky snap together model I did to make a holder for an SSD, an RPI4, and a cooling fan to run OctoPi.
I've completed many other machining and 3d projects using FreeCAD. Dunno, FreeCAD seems capable enough, at least for me. It's done everything I've asked of it.
If I remember correctly there was a major issue with how you set up the original coordinate system. I'm too lazy to go back and look at it again for arguments sake. I should point out that Fusion has a built in post processor, which used to be HSM. The post processor works very well (but not for 3D printing, where a dedicated slicer is magnitudes better).
A lot of people use FreeCad from what I gather, but I have never seen it used outside of a hobbyist role.
