- Jan 21, 2013
- 36
Very good. Thanks. One question, though - is the tool designed to swivel at the joint between the two halves or does it swivel where it mounts to the compound?
Yes, the tool swivels at the joint between the two halves. I applied grease between the two halves and tighten the screw only tight enough to allow the swivel movement. Use lock tight on the screw threads and a little grease in the counter sink.
