Sadly... with fully hermetic (sealed) compressors... the windings usually fail first.
It is the result of sloppy installs... moisture mixes with the oil in the compressor, and the heat of operation causes an acid substance to form. This acid literally eats the insulation off the windings of the motor inside the sealed can.
Lots of compressors get changed, due to acid. When we have an acid burnout... the entire refrigeration loop has to be thoroughly flushed... or in a month or so, one will be putting another pump in.
Separates the 'hacks' from the real service people...
