Rotating masses like shafts, rotors have an infinite number of planes in the Z axis, and basically in the X and Y axis you have to be able to determine the radial position of the heavy side (or light, whichever method you choose). The complication comes from the stresses imposed on said rotating mass at higher speeds in that the Z position is difficult to locate axially. The shaft or whatever tends to "bend" at higher speeds and therefore presents a "wide" zone in the Z axis that would show as heavy (or light) The trick seems to be to narrow that down as closely as possible while at the same time finding the center of that zone in Z.
I knew an elderly gentlemen who was a wizard at this fine art. FAA certified, built funny car engines for the big boys back when, but he isn't with us any longer. I believe his son is carrying on the engine work, but I don't know anything good or bad about his balance work, if he is even doing it. if memory serves, he and his dad didn't mesh too well, and they didn't work together much prior to his demise.
With properly placed arrays of piezo elements and accelerometers I believe it could be done. For my part, the software would be the Big Elephant in the room though. Been long, and way to foggy to begin to code such an application.
Of course, it would be simpler to just have something balanced on that rare occasion or buy a used balancer if static balancing would not suffice.
