Well folks, it's done!
I turned a thread on an unknownium arbor to match the 3/8" shaft thread, BSB, 26 tpi, this was my first go at threading, I nearly crashed it on the last pass, must have relaxed and forgot to pull the half-nuts at the shoulder! Just caught and scratched the top of the thread, phew...
a little filing and re-face the shoulder fixed it, not the best thread tool grinding in the world but OK for the need.
Well after messing about with turning the Tufnol to fit the brass hub, which went well and was good practice until I realized that I had got oil soaked into it so the adhesive wouldn't stick, I gave up on that and went with Acetol.
First problem was the very old BSP tap I that luckily came with a load of clutter I scrounged years ago, it was actually 25.5 tpi and jammed in the brass center! Very shoddy manufacturing, and can't blame the Chinese for this one, probably 60 yrs old! No way I was attempting internal threading, and neither of my retired machinists neighbors had one in there vast tap collections, so I used it and as only half the tap length was needed I hoped the Acetol would be flexible enough, and it is.
Got hold of some black Acetol, a little more flexible that Delrin apparently, but lovely to machine, got a bit tricky trying to turn the crown in between the flanges and I took a little too much off so effective diameter is a wee little bit smaller.
Had a few problems with chatter marks (this was quite pretty, and I noticed the original pulley suffered the same problem) when hogging out and finishing each side of the thinner part, I cured this by placing the old pulley rim against the chuck jaws behind the new one, it stayed in place without fixing.
Learned a lot about grinding special tools and also learned to quite dislike my lantern and four way tool holders because of the constant hieght re-setting.
Ordered a QCTP that arrives tomorrow, decided a wedge type would be a waste of money due to the limitations of my Atlas compound and cross slide,
http://www.arceurotrade.co.uk/reviews/MEW176_p022_25.pdf
http://www.arceurotrade.co.uk/Catalogue/Machines-Accessories/Lathe-Accessories/Tool-Posts I got the model 100
Thanks for all your guidance, which is much appreciated. :thumbzup:
Bernard
