- May 26, 2015
- 875
Sounds like good advice! Thanks. Truth be told, in the 15 years I've never cut any threads or tapers on any of the six or seven lathes I've owned. Does this only qualify me as just an expensive tool junky! LoLThe motorcycle chain grease that I tried lubed the gears OK for as long as it sprayed. It clogged after just a couple of uses and the rest was left in the can. Since I didn’t try it again I don’t know if that’s a common problem. The moly grease is applied with a cheap acid brush so reliability is 100%. Three dozen brushes at Harbor Freight runs about $3.00.
