- May 26, 2015
- 875
I know that straight cut gear teeth, on the back gears are noise prone, but is there a way to improve it a little? What about reducing the shims between the back gear where it's bolted to the head stock? Right now I have 10 thou on each side. Would that possibly encourage wear on the teeth? As far as I know that is the only way of adjusting gear meshing. It would be nice to quiet things down a bit when cutting threads!
