I bought a boring head without an MT3 adapter to use on the lathe or mill. So, I made one last night. After turning the 7/8-20 threads to a tight fit on the boring head, I mounted it between centers. First though, I mounted an MT3 taper reamer between the centers, and used the tailstock lateral adjustment to remove the longitudinal run-out on one face of the reamer. This was the first time I'd ever cut a taper. Colored the shank with a sharpie and tested the fit on the lathe by pushing it in. After using the dead blow hammer to get it out, the tells on the sharpie mark showed it was a perfect fit all the way down.
Excellent point! That's one advantage of using your compound (if it has enough travel) or taper attachment (if you have one) over the tail stock off set method.Good job! Just remember that when you set up to cut a taper like you did, the taper angle will be correct only for a part exactly the same length as your reamer. As your tailstock moves toward or away from the headstock, the angles get steeper and shallower respectively.
I kept that in mind. The part is maybe a 1/2" too long, because I chose the length to match the reamerGood job! Just remember that when you set up to cut a taper like you did, the taper angle will be correct only for a part exactly the same length as your reamer. As your tailstock moves toward or away from the headstock, the angles get steeper and shallower respectively.
I use a thin strip of metal held between center points to dial it right back in.
Searching more videos, I think tubalcain has an even easier way.Just for the sake of sharing information and different ways to skin a cat, here's a good video on a way I have used in the past to very accurately set up a taper using my compound.
Ted
