Um, "lost art" is a bit of an overstatement. I believe you can order babbit from any of the big supply houses and there is lots of information out there on how to pour a bearing. For example, Keith Rucker did a Youtube video recently on pouring a bearing for a sugar cane press.There is no replacement available, since babbitt has to be poured into the head with the spindle in one step and is now a lost art.
Craig
Maybe not a totally lost art, but something more like a blacksmith. There are still people that can do both, just not nearly as many as a hundred years ago. The company I worked for had it's own power house for generating high pressure steam and electricity. They also had a huge refrigeration compressor room filled with early 20th century ammonia compressors. The compressors were originally steam powered, and later switched to 200 hp electric motors. They had 12' diameter flywheels that ran on babbited bearings. The flywheels were partially submerged in a pit so the bearings were easily accessible for rebabbiting. The compressors ran 24/7 so every 3 to 4 years the flywheels had to be pulled and the bearings repoured.Um, "lost art" is a bit of an overstatement. I believe you can order babbit from any of the big supply houses and there is lots of information out there on how to pour a bearing. For example, Keith Rucker did a Youtube video recently on pouring a bearing for a sugar cane press.
Craig
Really? Something makes me think I saw someone do that in a YouTube video, appeared to come out nice. Unfortunately, cannot remember where I saw it... Maybe David Richards?There is no replacement available, since babbitt has to be poured into the head with the spindle in one step and is now a lost art.
If you compare a 2" spindle to a 4" spindle, identical in every other way, the speed of the sliding surfaces doubles, at the same rpm. The bigger the spindle bearings get, the more difficult the surface speeds become to accommodate with leading to overheating, galling, and failure. On the other hand, if only the diameter changes, and not the width of the bearings, load capacity is increased due to the larger total bearing area. At some combination of diameter, load, and speed, Babbitt bearings will need improved Babbitt alloys and/or better oiling systems. Automobile engines use Babbitt type materials at quite high rpm, but they have carefully designed oiling systems, with special oils, recirculated under pressure, good filtration, oil coolers, and highly accurate journals. You will not find that on simple and inexpensive lathes from decades ago...All ready own motor and vfd but still wondering about top rpm for those bearings. Previous post says dependant on bearing size , but doesn't give enuf info or formula to calculate. Unless it was assumed I know something I don't.
Sent from my VS995 using Tapatalk
Not sure why you say that. I believe babbitt bearings are pretty forgiving. When they are new, keep checking if they are heating up. Otherwise, a bad bearing could get to the melting point of the babbitt.Pouring babbit is not much different than casting lead. However to get it to be good enough for a machine spindle is a whole nother level. Compairing go karts to F1. No offense to Keith Rucker, I love his work.
