What part broke on you? Is the valve causing the issue or is It the tubing and connectors?
It was the valve. They seemed to corrode and stop working. The electric one has been in place for many years and for whatever reason has not suffered from the same problem. The compressor is electric so power was not a problem and the laundry tub was right next to the compressor so running the drain into the plumbing drain also worked out well.
