- Feb 7, 2013
- 792
I have been wanting to do this for a long time and the right part come up for grabs and I thought now would be a good time. As you can see in the photo I have two compounds the lower one is a stock 10 inch Atlas that broke in half as they frequently do. The other is a Atlas 12 inch commercial lathe compound that was for sale on this forum ( thanks Rick ) at a very reasonable price. The second problem is Atlas made a very short lower slide that offers very little support if for some reason you go past the slide as you most likely will and the tool catches the compound has had so much material removed and there is no support the compound snaps at the T slot. Plus the compound is so narrow and the dovetails are a little shallow the compound often rocks during cutting. Some guys have removed the compound made a spacer and use there QCTH without it so there is no give. ... Let's see if we cant fix that.
- - - Updated - - -
Since the commercial compound is off of a 12 inch lathe it is thicker I set it up in my band saw and cut off the dove tails. This is good cast iron and cuts like butter.
- - - Updated - - -
If your a purest of Atlas lathes please turn away this is after the cut I will mill the rest of the dovetail off. The casting will still be thicker in key areas because I will keep the tollerance tighter.
- - - Updated - - -
For the second part I got a piece stressproof I wanted cast iron but could not find any locally and I wanted to get started so stressproof machines easyier than cold rolled and its stronger so I started in.
- - - Updated - - -
Here I faced and bored the part I should mention the shaft is 5 1/4 in dia. it makes it an inch longer.
- - - Updated - - -
Here I took it over to my modified wood to metal bandsaw and cut out the shape.
- - - Updated - - -
I took the part over to my modified GO 727 mini mill and finished the shape I just cant leave any machine in its stock form it seems.
