- Jul 3, 2015
- 144
I just replaced mine (while still on the lathe) last week after finding that there wasn't any ball or spring in my gear. I used a small brass bolt for the pin. I cut it square on one end and rounded the other end. I too used a spring from a ballpoint pen but I had to check out several pens until I found a perfect fit/length. I made my pin about 3/8" long but the length and comprehensibility of the spring will determine your pin length. I dropped in the spring, dropped in the pin and then compressed it with a thin Allen wrench as I slide the plunger pin in place. Note that the vertical spring/pin hole in the gear also has a horizontal hole for the plunger pin that goes completely through the gear. While fitting the new parts I had them fall out several times through this hole so watch for that. It was very satisfying to hear the plunger "click" when I pushed it in and everything lined up.
