Atlas Shaper Help
I tried to get an Allen wrench in the set screw and then discovered that it's a slotted screw. I need to take the belt guard off to get a screwdriver in where the set screw is. The shaper is sitting in an inconvenient spot to work on it, so I'm going to have to get it moved before I can do much more with it.
I think the ratchet case on mine is okay, but I haven't had a real close look at it yet.
In the meantime, I started working on this index center that I picked up for it awhile back:
It's missing a few parts, but I think I can make most of them. And someone sprayed it with hammered paint. I'm going to strip it off and just paint the parts that should be painted.
Hey Joez, I know you sent me a private message but I can't find it. Can you send it again?
Thanks, Kevin
Hey Kevin
I may have entered stuff the wrong way that's probably why.
To add to this Thread and let you know about my custom change box.
I found a article in a old Magazine about a change box for the atlas 10.
I'm going to make gears on my shaper for my atlas 10 so I can make this change box.
I just have to fix a collar that (failed) on my Dividing Head
Joez
