- Jul 9, 2014
- 613
I have used a high grade alloy steel Bosch jigsaw blade to remove these nightmare nuts by simply ensuring the blade fits snugly in the nut slot then grind out the area of the bolt thread from the back of the blade , as these edges are almost perfectly square they tend to l bite into worn slots .
Once the " bridge " is made use a pair of mole clamp pliers to hold/push the blade square in the slots and then gently unscrew the nut
Sections of the thicker broken industrial hacksaw blades are also good for the bigger nuts that have a lot of thread poking through but you often have to kiss /grind the back of the blade on a grinder to a sharp edge before making the bridging cut out .
