Okay, I did find them. Then I got distracted by machining my QCTP for my little Taig.
But I did get a whole bunch 'o pictures, and took measurements first. Tell ya what. If you can provide dimensions and pictures of the assembly that goes under the table, I'd greatly appreciate it. Mine is busted, and I got to cast or machine another housing.
Anyway, here's my measurements. Mostly with a caliper, though some with a ruler.
The telescoping part is two round shafts, one nested in the other. A pressed dimple rides in a slot, providing drive.
The big (outermost) shaft :
6.25" long, .75" in diameter. The fork is machined into the end of the shaft, and the arms are 1" long.
The small shaft is .5" in diameter, 6.25" long (my best guesstimate by shoving a piece of wire down the outer shaft and comparing the exposed vs hidden lengths). The end of the small shaft goes into a U joint half, secured with a pin.
The slot in the small shaft is .125" wide, and can safely go the entire length of the shaft. I'm guesstimating it's .125 deep, based on the "around .125" depth I measured at various points.
The U joints have a .5" cube as the wobbling part,not sure about the pin (it's mushroomed out, and I'm too lazy at the moment to grind it and drive one out to measure).
The U joint on the small shaft is pinned to the shaft. The OD of the joints measures .87", the "base" the arms sprout from is .27" thick, and the arms are .75" long (from the top of the base to the end of the arm). I would surmise they're a tiny bit more than .5" between them, so the U joint works smoothly.
The big part of the shaft has the arms machined into the end of it, if that helps.
Lastly, the included photos show the phasing of the U joints. Yeah, I know it's a mess. It's broken, and I haven't even bothered with it in 7 years.
Don't be afraid to ask me for more measurements or pictures. It only takes a moment, and I can usually wrangle some shop time when I get home from work.
Here's the tool porn:
Hope it helps, and I would truly appreciate some pictures of the housing (the second picture shows mine is broken). I'd *love* power feed on my MFC, even if it's a DC motor driven jobber.
