- May 4, 2015
- 3,583
I figured on using thin brass washers on the top so it wouldn't drag , I think ill try it , got nothing to lose but time and a piece of aluminum . I plan on machining about a thirty degree angle an inch in on the top end , front and back may be enough to give it the boss effect. Try to make it look like it belongs with the mill.There is a guy who makes accessories for the atlas at mymachineshop.net who sells one for 199.00 but since you have a machine and a couple threads up there is a drawing whay not make one from medium or low carbons steel stock. I also bought a arbor and draw in bar from mymachineshop.net fair prices.
Aluminum might work but the attachment points might tend to wear in. Maybe T3 or T4 might work.
