- Dec 25, 2011
- 10,552
OK. I forgot that you were "building" a mill from parts. The Atlas mill had 12 model numbers.
M1, MF, MH (4-groove spindle pulley)
M1A, MFA, MHA (3-groove)
M1B, MFB, MHB (2-groove)
M1C, MFC, MHC (2-groove)
Of these, the MFx is generally the most common and considered the most desirable.
M1x Manual lead screw cross feed, infeed and table height
MFx Powered lead screw cross feed, manual infeed and table height
MHx Lever cross feed and table height, manual screw infeed.
Before you buy any more parts, you really need to get a copy of MMB5 (Milling Machine Bulletin 5), the combined parts list for all 12 models. And determine what model or models you have the most parts for. However, MMB5 has no operating instructions. For that get MMB1A or MMB2 for MxB models or MMB3 or MMB4 for MxC models. Some parts are interchangable between all 12 models down to some parts only apply to one model, and everything in between.
If you wish, since you still have several posts to go to get to 30 and direct access, PM me your email address and I will go ahead and send at least MMB5 and MMB3.
As best I have been able to determine, the 2-groove spindle and cone countershaft pulleys on the MxB and MxC take either a 4L section or an A-section belt (both 1/2"). The MFB and MFC motor belts are 4L350. I was told that one MFC was found with a Gates 3280 but haven't yet learned what it crosses to. The MFB and MFC spindle belts have different Atlas part numbers and I don't know whether this is because the belt length was changed or they switched from 4L FHP type to A Multiple type or something else..
