Atlas lathe need help with basic equiptment function
The pic you posted with the tag on the back of the bed- that is your model #. Look in the Atlas/Craftsman forum here for lots of good info. Around here, like in Utah as ttabbal said, that lathe with the tooling you got would make it worth $1200 to near $2000. Enjoy it! It will teach you many things.
I'm not a big fan of link-belts; they are a quick fix but you might consider pulling the spindle and replacing it with a conventional v-belt sometime in the future..
mark
mark
Why? I run link belts on my Craftsman 12" lathe and they run much smother and quitter then regular V belts.
I use Fenner Powertwist on my 3hp cabinet table saw, it is a single belt, and at the shop on anything that required hours and days of down time for a simple belt change. No issues at all.
I have heard that with Atlas's zamak pulleys they can cause accelerated wear because of the "hammering" effects of the links. I don't have any direct first-hand experience with this; many folks like them just fine
I believe there are a couple other disadvantages with them but I don't remember at the moment-they are more expensive of course
m
Thanks everyone. I got it all set up in my garage and it turns great compared to what I'm used to. I had an extra oxa qctp from my Chinese lathe and I made a t-nut and spacers with a longer stud. It's working good but I'm still going to order a axa and put a new belt on it. Unfortunately I smashed my only decent dial caliper last night while I was hand filing my t-nut. P.s. the leblonde lathe is still available in Western PA if anyone is looking.
Darn good deal I'd say, considering all the measuring tools and so forth. I'm surprised you didn't get a steady rest in the bargain
The Leblond you passed up may have been a better lathe per se, but one needs to look at the total package and intended usage- for hobby use the Atlas/Craftsman lathes are quite adequate and great values-good bang for the buck
m
I think that I overlooked some of the stuff that went with my lathe in the process of getting everything out of the basement because I thought there would have been one too, also only found 2 tool holders for the lantern tool post and both were 1/4". I thought that was kind of odd too because I won't even use 1/4 on my mini.
Now that I'm adequately set up I'm going to start my first project tonight. A bee stinger type bow stabilizer if anyone knows what that is. With some changes to not infringe upon patents and copy rights of course.
