I'm having chatter issues with my lathe. It's an atlas th54. First and foremost I do not have the wrong supported and its roughly 7" long of different sizes ranging from 3/4" to 1-1/2". I know I need support but I looked elsewhere. Check my bearings and had about .006 play using my 7" work to flex up and down. Tightened up the bearings and couldn't get better then .005 and now had a very notchy grainy feel which I was not satisfied with so I tore the spindle apart and found this but about 6 times more.
So at this point it threw everything in the parts washer and had to pick a ton of this stuff out of the bearings. Which by the way are dated 12-10-46. And they seem fun by hand now. I posted on another forum and everyone says its felt. I don't believe it as this is a soft plastic stretchy substance and there's about 3 varying materials I found in the front bearing. Do I need felt in these bearings? Or is it not something atlas had engineered into the headstock. Now onto problem two. Carriage play. Unscrewed apron and had a lot of movement. I didn't set up and read how much but I'd say by feel it was well over .010. So I tore that apart and found this
So at this point I'm well into the machine. I'm not doing a full restore just yet but if anyone has any insight as to what I should look into to better this machine is appreciate it. Right now my machine looks like this and is awaiting the weekend to get a much needed meet with some degreaser and the hose.
