- Nov 10, 2020
- 9
S o I have an atlas lathe that I am looking to get some more information about.
From my own research, it appears that a previous owner has taken a 10" headstock and mounted it to a bed from an Atlas 12" along with the 12" carriage and tailstock. It looks like they machined and adapter/raiser plate in order to bring the center-line of the spindle bearing inline with the center of the tailstock.
The serial number found on the bed of the lathe shows model number 3986, serial number 104562.
Any insight into the date and size of the headstock would be appreciated.
As of right now, the lathe appears to function without issue. My guess is it took a combination of 10" and 12" parts to get the gear train functional. I have limited pictures at the moment, but I can take more if necessary.
The carriage, cabinet and tail stock appear to be original 12" rather than modified from a 10. For example the compound slide is definitely from a 12".
The Atlas 3986 (and equivalent Craftsman model) are nominally 12x24 inch lathes with nominally 1/2" ways.. I have an Atlas 3996 which is a 12X36 and is the same except for length of cabinet, bed/ways. No where in the literature that I know of is the exact height above the ways of the headstock center and/or the tailstock center given. You will need to very carefully measure the height of the two centers and adjust one or the other t with permanently installed shims.
You will probably y need to drill two additional mounting holes in the salvaged parts depending upon the vintage ( serial number) of the 3986 as late production of the 12 " lathes had two additional mounting bolts that the earlier ones did not have. Nowhere did I find the date of this change
Other than that. I think that the lathe should be ready to use. WA5CAB
