- Jul 24, 2020
- 2
Thank you for the response. SEStephen,
The way that we commonly date ...
I'm finally getting around to posting data on my Atlas 10" lathe....
Here's my new addition to the shop:
Craftsman Atlas commercial 12 x 36 101.28910 Serial Number 107315
The 1/2 hp motor has a date of 1972. The date on the manual listed 1973 as the last publication date.
Well, it was probably made in 1973 as Atlas published an edition of the MOLO in 1971 and again in 1973 but not in 1972. So if it had been made in 1972 it would presumably have shipped with a 1971 MOLO. It does appear to be in good condition. In the event that you happen to remove the compound slide gib or the cross slide gib, please report whether the gibs are plastic or steel. They are probably plastic, which you will want to replace with steel. The carriage gib will still be steel.
Well, I guess that you have nothing to lose, as you won't get acceptable results with it bent. The only 10/12 steel gib that I have left is one for the cross slide. I have been meaning to ask the member who actually made them to do another batch but no one has asked for any of them recently and I keep putting it off. Is the gib bent at one of the counter bores or in a continuous arc?
I just noticed an odd thing, which is that the 101.28990 started coming with plastic gibs clearly well before the 101.28910 did. There are just too many reported for it to be a coincidence. FYI, those are the final two models that Sears was still listing when production ceased in March of 1981. We don't have enough of the Atlas badged machines reported to really draw any conclusions about them.
