Dan,
Thanks. If you have a scanner, scan the parts lists at 600 dpi to either a PDF or a TIF and send them to me at
wa5cab@cs.com
Here's what we now know or think that we know about dates and/or model numbers of the MOLO and the Craftsman 3/8" bed 12" machines.
The MOLO was first printed in 1937. The First Edition was Exact bound (glue and staples). The front cover looked pretty much the same as all subsequent editions except that it did not have the drawing of an outside micrometer on it. What color the covers were is not known. No copy is currently known to exist.
Probably the following year, it was reprinted, probably with the same contents, but the cover was dark blue, the micrometer was added to the front cover, and they used one piece spiral wire binding. The contents were probably the same, and the copyright page still said Copyright 1937. Probably in 1939, the cover color was changed to black. Between then and 1953, the only change to the copyright page was first the addition and then the deletion of "Price One Dollar". The first 15 editions all said Copyright 1937. In 1954, there were several changes, Coverage of the QCGB was added in Part 7 Threading. The Copyright page began to show an edition number, and the cumulative list of years in which the book was reprinted.
The one-piece spiral wire binding became two-piece and then 3-piece. At some point, probably near the end of WW-II, the binding changed to GBC (white plastic fingers). For more details, see MOLO HistoryRev6.pdf in Downloads. And the companion MOLO To Machine App Rev3.pdf.
On the Craftsman lathe models and dates, there were a total of 14 models of the 3/8" bed 12" produced between 1936 and 1957. Except for the final two, the model number did not define the bed length. If it had, there would have been 38 different model numbers. In 1936 the 12" first appears in the Craftsman Power Tools catalog. There were two models, the 101.07380 with back gears and the 101.07360 without. Both had babbit bearings, 5/8" dia. lead screws, no power cross-feed, and 3/8" face change gears. And both were produced in four different bed lengths. In 1937, the 101.07400 with Timken bearings and full belt guards appeared. The model numbers were incremented with for some reason the Timken model lagging by a year. Various changes were made up until 1939 for the babbit bearing and 1940 for the Timken model. The change gears were changed to the -A rev with 1/2" hub length and 64T maximum number of teeth on the 101.07xx2 models. And in 1940 the 101.07403 added the power cross feed. The babbit models were discontinued around 1945. The 36" and 48" beds were discontinued around 1947. The QCGB came out in about 1952, and for the first time, the model number defined what bed length the machine had. Production of the 3/8" bed models ceased sometime in 1957.
