- Dec 25, 2011
- 10,552
Ideally, the four lathe feet mounting points should be in the same plane and the six floor anchor points should also. Are you going to anchor the cabinet to the floor or slab?
One thing that you should do while the bed is unloaded is to replace the rubber grommets between the drip pan and the foot mounting points on top of the cabinet and right leg.
Also, when you start putting the thing back together, start with the headstock and make sure that the grooves in the spindle pulley and countershaft pulley line up. And that the belts have as much clearance as possible between them and the cutout in the pan. My 3996 came from the factory with the bed too far towards the tailstock end. It shreaded the right-hand belt within a month or two. And I discovered that the pulleys were not lined up. When they were lined up, the set screw in the countershaft pulley was clear of the end of the shaft. I've been running the machine for years with one belt in the left spindle pulley groove and right countershaft pulley groove. Sometime this Spring (I hope) I am going to pull the spindle to replace the belts and try to put everything together properly.
Robert D.
Robert D.
