- Feb 13, 2017
- 2,138
HSS shear tool. . .
... Anything less than about 5 thou depth of cut results in a surface with grooves and such with 2 thou differences over the length. ... This pic is of my 4th attempt to cut a 3/4" diameter for an arbor.
The pic is 2" round bar. The left side was cut with the same carbide tool as the right. Same DOC & feed rate.
It's not limited to the PM1440GT but more a function of the style/design of cross slide and compound on a lot of the import machines. At the end of the day it is still a hobby class lathe, though quite capable for it's size, there are areas that can be improved to squeeze out more performance.I wouldn't have thought you'd have rigidity problems with something as big as the PM1440.
