- Jul 6, 2022
- 533
That one cutter is for cutting radius's on edges smaller diameter then the radius. It sounds as if the ram has burrs on it or you tightened the gib to much. I would leave the sets screws finger tight and move the ram and after tighten them to lock the ram in place. No need to machine it. Here take a look at how my student Keith Rucker tightens his scrole to 7 minutes or so. Leave about .002" play or .005" when loose for moving. It is a different type but the principal s the same.
Thanks Richard. I checked for burrs and did some light sanding and cleaning to get the grime and gunk off before putting the ram (over arm?) back on. I haven’t even put the grub screws in, and it’s still stuck. I’m now worried that the over arm of mill itself may be out of shape. I need to hammer the over arm back out and take measurements in several places to make sure one of them isn’t warped of dented.
Thanks for the info on the cutter. That makes sense. Seems it’d only be useful for a specific size of plate?
