MC40,MC60,MC80 boards are great for driving DC motors
KBC drives are proven assets
Dart drives are great DC drives
treadmill motors work very well
I work with higher end VFD's equipped on the machines i work on, but i use very inexpensive VFD's in my shop
My philosophy is that i can buy 3 or 4 inexpensive drives for the cost of a high end drive
the high end drives don't really power the machines any better than the low end drives in my experience
i have not had a single failure or experienced any of the horror stories others will lead you to believe.
this is on heavily used equipment- milling machines, lathes, surface grinders, pedestal grinders, tool and cutter grinders
for this experiment of 8 years on varying equipment and many cheap VFD's , i'll give the inexpensive VFD's a nod of confidence.
i figure if i do ever loose a VFD, i'll spend only a few $$$ and be up and running again
instead of spending for several hundred or up to thousands on a drive, i have been stocking my toolboxes with the money i have saved
the best motors to use with VFD's are inverter rated, but don't let that stop you
most motors can safely be operated for short periods of time out of the 60Hz envelope
a safe zone is 30 to 90 Hz for normal induction motors
for inverter rated motors the envelope can be very low 5hz or so up to 400Hz
