I recently made 10 tool holders . One thing I noticed, after breaking a few inserts, was to take smaller cuts as you increase the depth of the dovetail. The first cut could be as much as .010, but as you progress, the insert is exposed to more material that must be cut, so, reduce the cut, depth. After about 4 passes I reduced each pass a little more and finished with .005 per pass, saves the carbide insert. After I learned this I havn't ruined any inserts. Also use the biggest dovetail cutter that you can fit .
