- May 4, 2019
- 810
**GT inserts are intended for cutting aluminum. They work very well cutting steel especially on low HP machines.
There are lots of ccmt aluminum inserts but the ccgt seem to be coated and work killer on steel that tears instead of cutting nice.G is the tolerance and T is the hole/chipbreaker, correct? What does that have to do w/cutting aluminum?
The "G" tolerance is tight enough that the insert has to be ground or honed sharp after it's out of the mold to meet the tolerance specification. A "M" tolerance is sufficiently sloppy that the inserts coming out of the mold will meet that spec without any further tuning and generally have a more blunt cutting edge. The degree to which the chip breaker alters the geometry to present a positive cutting edge is a function of the manufacturer's grading specification. Some CCGT inserts will have a pronounced spoon-shape behind the cutting edge, others will not - it all depends on the chip breaker spec and grade.G is the tolerance and T is the hole/chipbreaker, correct? What does that have to do w/cutting aluminum?
I wish there was more visibility as to amount of positive rake the inserts have. It's tough to determine exactly what you'll be getting other than CCMT=positive rake.The "G" tolerance is tight enough that the insert has to be ground or honed sharp after it's out of the mold to meet the tolerance specification. A "M" tolerance is sufficiently sloppy that the inserts coming out of the mold will meet that spec without any further tuning and generally have a more blunt cutting edge. The degree to which the chip breaker alters the geometry to present a positive cutting edge is a function of the manufacturer's grading specification. Some CCGT inserts will have a pronounced spoon-shape behind the cutting edge, others will not - it all depends on the chip breaker spec and grade.
You are correct. Those two sizes are the same.I wish there was more visibility as to amount of positive rake the inserts have. It's tough to determine exactly what you'll be getting other than CCMT=positive rake.
Does anyone have experience with CNMG inserts on a smaller (~10" 1hp) lathe? I'm thinking I'll end up going CCMT 21.5X for OD holders and boring bar. But am still curious how the CNMG does being negative but having a positively ground insert.
Anyone know of a quality 1/2" SCLCR holder that takes the 21.51 size insert? I see kennemetal makes one for about $75. Any other options I should look at?
Also, are the ISO inserts a direct replacement for the ANSI inserts? It seems like kennemetal makes whole different holders for CCMT0602 inserts and CCMT21.5X although the shank dimensions are actually 12mm instead of 1/2", so that may be the real difference. Are CCMT 21.5X and CCMT0602 completely interchangeable?
