43. CLEANING THE CHUCK (con't)
I soaked it in Simple Green for a few days. Got it nice and clean.
So I did some research on what to use for lubrication. The chuck lubrication debate rages on the internet!
Moly-graphite grease seems to be a popular choice. Some people don't like grease because it attracts swarf. Others use oil, but sparingly so it doesn't fling off. Others use spray graphite. My machinist colleague at work says any machine grease is fine for my application, which is occasional hobby use.
The MOLO states: "Keep the chuck clean and do not oil excessively--a light film on all working parts is ample." It also states that "...sticky jaws indicate that the chuck should be taken apart for a thorough cleaning." It goes on to say "When reassembling, do not apply too much oil. Oil collects dust and chips which sooner or later clog the chuck mechanism."
My take is this: If you are using your machine for production then what type of lube you use is more critical than if you are a hobbyist. Use either oil or grease, depending on your situation. And no matter what, clean your chuck once in awhile.
44. TAKING APART THE CHUCK
I took the 3 socket screws off the back, but the plates won't separate. Are they press fit? Is it just the oil film keeping it together?
Couldn't find any decent instructions for doing this. There's a thread on this site, but it completely skips removing the scroll plate. I will make a few attempts while I await all your wisdom!
