- Jun 10, 2019
- 537
@Alcap - living with both styles, I'd go with a non-threaded bore and set screw. I feel tools are a bit easier to make. But as long as all your tooling is designed to bear weight on the ram and not the threads: you should be good to go.
I just made a 3/8" socket adapter for my new arbor press last night. Here's some #'s in case it helps:
My last tool looked a bit sloppy with the punch marks to retain the ball, so this time around I wanted to properly swage. I found that a 5/16"-18 set screw works as a swaging tool in a pinch. You'll want to use the allen head side to do the swaging and put a pin the allen head as a pusher to depress the ball. This little bit of metal should stick up out of the allen head by just a little bit to ensure the ball is depressed enough before the tool contacts the surface.
I made a quick press tool to hold the set screw in my press so it wouldn't launch sideways across the garage. The metal pin i used was a cutoff from a finishing nail. I did end up making it quite a bit shorter than what you see here, but should give you an idea.
Final result. The 2 rings are because I didn't properly center the tool the first time. It was easy to set the ball using a 3T arbor press. Seeing that there's only 1-thou of clearance, it doesn't need much to deform and retain the ball.
- Ball bearing diameter: 0.1855"
- Bore: center of bore was 0.205" away from the tool face which the socket will butt up against. Drill with #15 to 0.300" deep, then ream to 0.1865"
- Spring: 0.160" in diameter, wire size is 0.023". I cut a length 0.250".
