- Jan 22, 2011
- 8,016
OK guys....I know someone will be able to answer this.
I have a Colt AR15 that has a unknown make .22LR upper and we'll call it a "sliding, retractable" buttstock. The spring and buffer are what came with the conversion, but I an seeing a couple of things that make me suspicious. I get a stovepipe pretty often, and even more often, a round is chambered, but the rifle fails to cock, so no fire. I am beginning to think the buttstock bore that houses the spring is shorter than stock, and that changes the characteristics of the spring. If the blowback is not sufficient to recock the firing group, is this a possibility? If so, what to do about it? I do not have the original stock to get any measurements from.
