- Nov 25, 2015
- 10,034
I'd rather not take apart my kant twists.
But I'd like to modify them and put a V in the proper way. I don't know what they were thinking putting them in the way they have them.
I am always needing to grab a round part at 90.. not parallel.
But I don't want to grind out the riveted shaft. It's probably a harder steel, and is strong enough to clamp. I have no problem riveting, but I just don't want to do this one.
If you did, how did you hold it. I am thinking I might get by using a parallel clamp, then putting that in the vise.. But fearful it will move. Also aligning both grooves will be a challenge.
