- Oct 11, 2016
- 4,008
Anyone got any idea what the weight of the knee including tables might be? I am guessing 500 lbs but someone might know better. Thanks if you do.
These jive with my weights +/- 10% My Hartford knee is 275 lbs, and my First is a little more, at 300 lbs(but it has a bigger table, and longer Y axis).Some weights posted by another person for a Bridgeport j head mill with a larger table
As for reducing wear on the bevel gear, the most common wear cause is swarf that drops onto the bevel gear. cleaning it regularly and putting a soft shield (such as rubberized fabric) to prevent swarf from getting jammed in the gears is a far more valuable way to preserve the two bevel gears.
My Hartford is 45 years old, used daily in a tool and die shop, with the gears caked in steel and aluminum swarf - with a good clean, it works perfectly. And it probably will continue for another 20 years like this.
My First has a 'sorta' shield over the bevel gear, and they are brand new looking - even has some of the machining marks still on the gears. It is from about 1977-78, used every day in a production shop.
