Anyone have an import dividing head? BS-0 or similar?
The screw and washer are used to lock the two sector arms together to count the number of holes on the index plates.
So was the one from PM deburred with the sharp edges removed and was it free from interior debris and swarf ?
Aside from the shipping damage, was there any material difference between the two ?
Can you be specific about what failed QC? Assuming the cracked casting was shipping damage, was the damage apparent without disassembly ?
Thanks,
-jd
I think you should start your own thread on this, instead of thread jacking. Be glad to answer on that thread. This thread is about the spring clip on a BS-0.
I bought a BS-0 dividing head from Precision Matthews. I took the handle off to adjust the backlash. There's a retention spring right before the "clock hands" to keep tension on them. When I put everything back, when I adjust the "clock hands," it pushes the tension spring out of the groove and it pops out. I've been messing with it for hours now and I cannot seem to get it to stay. I'm not sure what I'm doing wrong.
I've even tried pinching the spring with the hands' locking screw.
The "wings" of the spring washer are hitting the washer under the screw. That has been noted, several times. I didn't get mine from PM, it is likely a generic, Grizzly at best. I've never had that problem. Looking at the video, the first thing I would try is inverting the spring washer so the wings stick up a little. Then maybe use a smaller washer under the screw. Or even a "fillister head" screw without the washer, if you can find one. The washer under the screw is the obvious problem. It could have been installed offset to eliminate a known problem at final assembly. I wouldn't recommend grinding on the spring washer, but if that's what it takes. . .
The only time you'll be moving the two sector arms relative to each other is when you are setting up for a particular spacing... just move the spring by hand to keep it from popping off. It's not like you be moving those sector arms around a lot like you are on your video. You'll move them for the proper hole spacing and then lock them in place for actual indexing. They will rotate as a unit for indexing.
Ted
Placing the spring under the washer like this works great on my PM BS-0.
