- Sep 22, 2010
- 898
I'm going to give the guy with the no5 a call.
Dave I'll send you a pm with my contact info if the no5 sounds like 5 miles of bad road maybe we can work something out.
Walter- I am jealous beyondd belief! awesome set up, tooling and press!
Jer
Jer
For what I do, that press is awesome. It has a couple of draw-backs, the height is a bit low at 12" and the hole through the tabel a bit small at about 3-1/8"
I have a couple of sizes of bearing knives, and they are used most ot the time to form the table support. I did not get a turret with it, and even on other ones I have used, rarely used the turret anyways.
I have recently added another set of sleeves to the inventory.
The set of sleeves shown in the cabinet doors, are 9.55 mm x 6.15 mm up to 49.26 mm x 42.86 mm in both 38 mm and 101.5 mm long. It was a service fixture available to repair shops for Porter Cable and came on a wood carrier as shown on the bench in this other picture of a friend's shop. I found that mounting them in the doors of the cabinets worked better and kept them from getting bounced around, taking less room on benches etc.
The set I added is the Mueller Kueps which goes from 44 mm (38 mm) x 34 mm up to 82 mm (76 mm) x 72 mm in 55 mm long in 2 mm steps, with an internal step at one end so that they can nest together.
As for the stand, if I was to do it over again, I think I would aim more towards a roll cab tool box and have it set up so that there could be the sleeves and storage of press fixtures in the drawers of the cabinet. As it is it is mostly just wasted space under the press.
Walter
