Well, I took another quick look at the board searching for the diode bridge. I found it, and bridge is comprised of 40HF30 diode rectifiers. They are still available at $9 a pop. Each is rated at 300v and 40A. It also looks like what "smoked" on the case is not the DC switching wire. It is one of the 110v ac feeds TO the bridge that is missing a wire nut. I did not have time to dig out the multi-meter, but I will. I need to make some time and study this a bit more. Right now, my theory is, the 110v wire touched the case, and blew the fuse. The previous owner in his haste to figure out what happened, broke off the DC switching lead, and also put a new fuse in ( looked at the broken connector closely, and there are no carbon or fusion marks, just a clean fracture). I am making the assumption that the DC switching leads are series, NOT parallel. If that is the case, all connections must be in place for the motor to work, regardless of direction. However, those are assumptions, and not based in "advanced schematic digestion". I am only so-so on electronics, but I know enough to be dangerous. More to come
