- Dec 18, 2019
- 7,694
Not up to the high standards that have been set here, but here is my initial entry. Semi wrap around on 1.5" 80/20. No fasteners needed. Printed a 5 degree wedge that goes between the 80/20 and the splash guard, which tilts the 80/20 up by 5 degrees. Design based on vtcnc's post, but designed for 1.5" 80/20. Hope it holds up, if not, I will design something else. Tight but sliding fit on the 80/20. I have since widened the cross section on the vertical from 5mm to 8mm. Draft mode, 0.3mm, 20% infill, 3 wide perimeter. Made 11 holders.
Need to work on holders for my drill chuck and live center. They will need to be made a bit sturdier.
