That is a pretty slick idea for doing gun barrels but it doesn't have anything to do with the final finish. The reason is to keep the end plugs from popping out of the barrel after it's heated in the tank. The air inside the barrel expands creating pressure, and blowing the plugs out - getting the solution inside the bore where it is not wanted. Having more pressure on the outside of the barrel vs inside the barrel prevents this. :thumbzup:A long time ago I made a pressure bluing tank for a old gunsmith out of PVC pipe with threaded end caps and a fitting for air, he would add bluing to the pipe close it up and add about 10 lb. air pressure to the pipe and put the pipe in a heated bluing tank and he said it worked real good. I am not sure if it will work on your stuff, but would be nice to know if it works better, since I never seen the finished product on the gun barrels.
Paul
In Tony's case he wants to finish the inner bore as well - if I'm not mistaken....
Manganese Phosphate:
