- May 31, 2018
- 184
The half nuts have adjustable gibs on them also (or at least mine did) so it's worth checking to see if these need adjusting too. There should be some resistance however as I found out - if you set them too slack they have a habit of jumping on the lead screw which can completely ruin a part when threading!
As for the carriage, presumably the hand wheel is stiff to turn? As has been mentioned before it could be the gib adjustment. One way to check this would be to remove the large 8mm hex screws on the carriage that hold the apron in place. Be careful doing this as I can't remember if you need to remove the lead screw or not to do this. Thinking about it you probably do.
With the apron off you should be able to move the carriage back and forth by hand. If it's a problem with the gibs then you should feel the tightness (i.e. it will be difficult to move). If all moves freely then it's a problem with the rack gear. As a side note, the gearing for the handwheel is very prone to getting chips stuck in it. Many people have made covers for the back of the apron to help with this. It could simply be that chips have worked their way in there (will generally rotate freely and then get stuck as a chip jams the gears). On my lathe the apron would end up coming off every few weeks to dig the chips out. Really should have made a cover for mine but didn't have a drill press at the time and didn't fancy drilling the holes by hand. Plus on my variant of the mini lathe clearance at the back is not great.
As Roy said these machines benefit from a rebuild in the early days. It does sound like a complete ball ache but it really helps you to get to know your machine (helps massively with troubleshooting later on!) and it means that the lathe is properly adjusted so you will get the best results possible from it. Sure you may not get everything perfect first time (as a number of these adjustments take a bit of experience to get the sweet spot) but it will likely run a lot better than out the box and you gain a heap of knowledge of how the machine operates in the process!
