A user named "EddyCurr" made a test of the DD on some bits over at HSM:
http://bbs.homeshopmachinist.net/showthread.php?t=51863&page=5
A neighbor's no-name 3/8" drill
Before beginning.
After a first pass. A check with a drill gage showed an angle of 122º
and a visual of the heel suggested the relief angle was shallow. The
width of the chisel edge measures 5/64" (1.98 mm).
The wheel is the OEM 180 grit. It leaves a coarse finish but it does not
have much use at this point. Perhaps after some wear knocks down the
high spots, the wheel will leave a smoother finish.
Some steps/facets are apparent. The expected result on the end face
running from the cutting edge to the heel is supposed to be one
smooth continuous surface. The trouble-shooting section in the
manual suggests the steps may be due to hesitant wrist action - I
thought I worked the chuck smoothly.
After a second pass.
Before continuing, I reduced the drill point angle setting so that the indicator
arrow was aimed at the base of the '118º' numerals instead of at the middle
of them. This change reduced the finished angle from the 122º shown above
to the desired 118º.
Also, during the step for positioning the drill in the chuck, I inserted the
chuck one notch CCW (to the direction of '+' on the sharpener) from the
straight up (12 o'clock) position. This increased the relief angle.
After resharpening to reflect these changes, a Split Points operation was
performed. As shown, I believe that the points are Under Split - too little
material has been removed to be considered an optimal result. The chisel
edge shown measures 1/32 (0.79 mm). Oh well, it is narrower than as
supplied new. Both cutting edges are equal in length.
The steps/facets are present again. If anything, they are more prominent.
I was consciously trying to be smooth. (I am thinking about applying
some kind of lubricant to the surfaces between the chuck and the
receptacle it rotates in for the next trial.)
The face shown in the right-most image appears dark as if over-heated.
This is just a result of lighting, it is bright to the eye.
More of the neighbor's drills
A 5/16" before beginning.
Notice that the finish is somewhat less coarse - perhaps due to some wear,
but also likely a result of reduced feed pressure.
Also notice that the steps/facets are gone. The machine had been operated
on top of a piece of corrogated cardboard on the bench - I saw that there
was some movement during sharpening and found that the faceting went
away when the machine was held firmly on a solid surface.
This is a 1/4". No 'Before' image, but the 'After' shows improved results, too.
Back on the surface finish.
