Any tips about turning A36?
Anchor Lube is water based and can be thinned with water as needed or desired. It is easy to squeeze a couple drops of Anchor lube on your vise, add a drop or two of water as needed to thin for what you want, mix it with an acid brush and apply a thin coating to the work. If you put big globs on spinning work or cutters it just flings off, wasting it and making a mess. A thin coat is all you need, reapplied as necessary.
