John,
Carbide works well with high speeds and heavy rigid lathes. They are fragile and do not like interrupted cuts. Small, light, or old lathes (slow) usually do not yield good finishes with carbide. Learn how to grind HSS and you will get much better finishes for less money invested. If you are using a light lathe and are using carbide make sure you are using a positive rake cutting tool. Negative rake will also yield poor finishes on a light lathe.
Chrispy
Chrispy
