So I googled around the web this morning and came up with some interesting rpm numbers.
Most people recommend a 30:1 gear reduction motor to bring the typical 14" diameter wood bandsaw machine down to metal cutting 100 SFM.
100 SFM with 14" diameter wheel means the wheel needs to turn 28.28 RPM. That is Slooooowww.
Some guys actually drag their bandsaw over to their lathe and put a v belt on a jack shaft into the lathe chuck and use their headstock to turn the bandsaw that slow.
Couple other people said they were going to convert their bandsaw with a D.C. Variable speed motor, but never reported back how successful they were.
Think I will keep looking - to many projects already not getting down to add a bandsaw conversion to the list, I need the bandsaw to do the projects - not the other way around.
Or maybe I will just break down and get a plasma cutter. Problem solved!
Glenn
