- Nov 25, 2015
- 10,039
I bought a while back some offshore brake rotors to setup as an emergency brake on the lathe, along with adding a relay to disable power.
I made a new pulley for the motor and was trying to align the bolt hole pattern. I scratched it out and wanted to make sure I had the program setup.
Well, I could not get the bolt hole pattern to align with my scratches. I decided to put the rotor back on and it doesn't align, turn it , still not. turn it again, now it's aligning. Are bicycle hubs not symmetrically drilled?
