There usually significant differences in cost when it comes to bearing classes. I would not be inclined to spend the money for higher class bearings without substantial reason. So unless you are using the drill press as a power head for something other than the factory application, you probably would be hard pressed to differentiate, in operation, between the OEM selection and anything better.
