F
f350ca
Forum Guest
Register Today
Good scores!
Don't think 126 is the weight or my 1256 would be falling through the floor. Found a catalogue reprint on one of the black smith forums, it listed face sizes to corresponding weights, of course mine didn't line up. Thought mine was 250 pound but has a 1 1/4 hardy hole, that indicated 300# by the catalogue. If you compare yours to other anvils I think you'll find it doesn't ring that bad. From what I gather they forge welded a hardened plate for the face to the softer steel body. That reduces the ring which is a sought after attribute. I've used other anvils that were good but were deafening. As you've checked its the bounce test that indicates quality.
The edges on yours are a little worn but serviceable, the face looks pretty darn good in the photos. I'd leave it alone.
Greg
Greg
