- Jan 21, 2021
- 28
@davidpbest Greeting David, do you advise on changing out the oil and cleaning the headstock before using the lathe?
When I received my PM-1340GT, I drained the headstock, took off the top cover and inspected everything inside the headstock casting.
The oil was crystal clear, and I found zero grinding dust or swarf in the headstock. So I would recommend you run the lathe through a break-in procedure first - something like 10 hours of spindle time total making sure you’ve run it in all the headstock gear setting for at least 30 minutes. That break-in will certainly dislodge any burrs on the gears, and while I don’t think changing the oil after 10 hours is really necessary, doing so will give you the comfort of knowing you did so.
Draining the headstock can be very messy because of the position of the drain plug. I decided after my first draining experience to install an oil drain plumbing system that makes the procedure super easy and totally controllable. You can see that in this photo:
Be careful refilling the headstock with fresh oil - it’s easy to not see the fill line in the sight-glass and over fill - you’ll know you’ve done that when the spindle bearings begin to ooze oil all over the bedways (been there). Congratulations on your new lathe - I really love my 1340 and continue to be amazed at what’s possible with
David,When I received my PM-1340GT, I drained the headstock, took off the top cover and inspected everything inside the headstock casting.
Be careful refilling the headstock with fresh oil - it’s easy to not see the fill line in the sight-glass and over fill - you’ll know you’ve done that when the spindle bearings begin to ooze oil all over the bedways (been there). Congratulations on your new lathe - I really love my 1340 and continue to be amazed at what’s possible with it.
I'm just curious as to what was the date that your order was placed? I'm afraid I missed this shipment by a hair, not that it matters. Here's to hoping that a September arrival isn't delayed again.Finally! The 1340GT is here!!
I'm just curious as to what was the date that your order was placed? I'm afraid I missed this shipment by the a hair, not that it matters. Here's to hoping that a September arrival isn't delayed again.
