Just a side note, something I have thought about while leveling the lathe the first time around, and then this most recent time. I kinda wish the lathe was HEAVIER. I find that adjusting the feet will occasionally lift other load point to where it is not touching. Say like jacking up the front tail side I will sometimes find the rear tail side is lifted off its pad.
If I had this to do over again, I would drill and anchor studs into my slab, and then make the adjustments on those studs, with a nut above and a nut below the stand so I can (once very close) force the bed to do what I want it to do, even if gravity is too weak to do it. The current system now, where the stand is threaded for adjustments, and then a locking nut is beneath the stand itself is a mid of a PITA. I wonder if I put the Jam-nut on the wrong side of the equation now. trying to lock the adjustment actually lifts that point due to slop in the threads. and each threaded point is slightly different. Therefore you spend hours making slight adjustments to level the lathe and minimize twist, and when you finally get the Bubble where you want it and try to lock it down with the Jam nut, you move the lathe.
I may make this change before I start this whole process again. If nothing else, I imagine it would help with rigidity overall.
