Swap all of your oils to a way oil, the apron will work with it. Oils are classified as hydraulic fluids, lubrication oils and coolants. the ISO grade determines the viscosity. An oil like DTE light works good for a general lubrication, it is a ISO32 grade, DTE medium is thicker and is an ISO 68, DTE heavy is an ISO 150. Way lube like Vactra 2 is an ISO 68 but a different kind of lubricant that is sticky where the DTE is more like a general purpose oil. When you start mixing brand names into the mix, it gets real confusing. Tim
