I don't believe so... because turning the gear 180 deg. is just putting the newly ground tooth slot in the pinned position for the next tooth to be cut.
.....so your doing one tooth at a time..... I really don't know <grin>
However that is not the method I used to make my aluminum gear from scratch, I used the double gear method and more or less just copied the teeth of the gear beneath the aluminum blank ... sense the aluminum gear blank is Pinned to the old gear I am copying, all I had to do is make sure the old gear had a pin or stop to keep it from turning.... and then use that to re position the 2 gears after each cut.
I must admit that putting it in and taking it out of the milling vice 34 times was a tedious process indeed ! i will be real nice to that gear and be real careful with it because I do NOT want to make another one ! LOL......
.... if anyone out there is thinking of doing what I did with a homemade fly cutter....think again ! it would be 10 times better if you just bought the gear cutter and made your own arbor to fit the cutter ! ..... I used what I had in pure Ranch hand fashion.... in the end I noticed that my hunk of file I had so carefully shaped ( but was still quite a bit off ) had cracked and broke long ways..... rendering the cutter useless after this use. but it did the job that is what counts. because I shaped the cutter by eye and used no measuring instruments at all, I wound up having to file every tooth on that gear by hand
....if I would have used the correct cutter to begin with that would not have happened...so lesson learned !
as a side note .... I notice at about tooth 31 that the milling vice was flexing quite a bit as I clamped down on it real tight
I couldn't see anything wrong but when the gear Jig was removed the vice itself had alot of play in it..... so I investigated to find that the gib had slid out the back of the vice and was butted up against the end of the vice.... leaving the front half of the vice with alot of play...
that repaired and gib tightened fairly snug I finished the teeth cutting with no more issues !
.....that has been the most extensive use of that vice in the 3 in 1 in its entire lifetime,..... and I also find that the front gib screw is stripped out !
so I got more repair work to do ! the 3 in 1 has been a lifesaver on the Ranch and now it just saved the Logan 922 so all in all it has been a good tool even though it is way too small ! it was the cheapest Mill,Drill,Lathe that Harbor freight had about 30 years ago . and it's still going strong.
later all
Bob......
